Application Note AN-4147Design
消耗积分:5 | 格式:rar | 大小:153 | 2009-11-27
h1654155275.3301
分享资料个
Application Note AN-4147Design Guidelines for RCD Snubber of Flyback Converters
www.fairchildsemi.com
© 2006 Fairchild Semiconductor Corporation www.fairchildsemi.com
Rev. 1.1.0
Abstract
This article presents some design guidelines for the RCD
snubber of flyback converters. When the MOSFET turns off,
a high-voltage spike occurs on the drain pin because of a resonance
between the leakage inductor (Llk) of the main transformer
and the output capacitor (COSS) of the MOSFET. The
excessive voltage on the drain pin may lead to an avalanche
breakdown and eventually damage the MOSFET. Therefore,
it is necessary to add an additional circuit to clamp the voltage
评论(0)
发评论
下载排行榜
