开环spwm程序
消耗积分:0 | 格式:doc | 大小:42KB | 2017-10-07
EthanCoen
分享资料个
SPWM程序
  #include “DSP28x_Project.h” // Device Headerfile and Examples Include File
  #include “math.h”
  // Prototype statements for functions found within this file.
  void InitEPwm1Example(void);
  void InitEPwm2Example(void);
  interrupt void epwm1_isr(void);
  interrupt void epwm2_isr(void);
  // Configure the period for each timer
  #define EPWM1_TIMER_TBPRD 7500
  #define EPWM2_TIMER_TBPRD 7500
  #define PI 3.1415926
  Uint16 k1=0;
  Uint16 k2=0;
  Uint16 N=200;
  float Comp1=0;
  float Comp2=0;
  float Comp3=0;
  float Comp4=0;
  float M=1;
  void main(void)
  // Step 1. Initialize System Control:
  // PLL, WatchDog, enable Peripheral Clocks
  // This example function is found in the DSP2833x_SysCtrl.c file.
  InitSysCtrl();
  // Step 2. Initalize GPIO:
  // This example function is found in the DSP2833x_Gpio.c file and
  // illustrates how to set the GPIO to it‘s default state.
  // InitGpio(); // Skipped for this example
  // For this case just init GPIO pins for ePWM1, ePWM2, ePWM3
  // These functions are in the DSP2833x_EPwm.c file
  InitEPwm1Gpio();
  InitEPwm2Gpio();
评论(0)
发评论
下载排行榜
