The AD9058 combines two independent, high performance, 8-bit analog-to-digital converters (ADCs) on a single monolithic IC. Combined with an optional on-board voltage reference, the AD9058 provides a cost-effective alternative for systems requiring two or more ADCs. Dynamic performance (SNR, ENOB) is optimized to provide up to 50 MSPS conversion rates. The unique architecture results in low input capacitance while maintaining high performance and low power (《0.5 W/channel)。 Digital inputs and outputs are TTL compatible. Performance has been optimized for an analog input of 2 V p-p (±1 V; 0 V to 2 V)。 Using the on-board 2 V voltage reference, the AD9058 can be set up for unipolar positive operation (0 V to 2 V)。 This internal voltage reference can drive both ADCs. Commercial (0°C to 70°C) and military (–55°C to +125°C) temperature range parts are available. Parts are supplied in hermetic 48-lead DIP and 44-lead “J” lead packages.
