Kunststoffgeh‰use Geh‰usematerial UL94V-0 klassifiziert Weight approx. ñ Gewicht ca. Periodische Spitzensperrspannung Plastic material has UL classification 94V-0 ! ! Terminals: Plated Leads Solderable per MIL-STD-202, Method 208 ! Polarity: Cathode Band ! Weight: 1.2 grams (approx.) ! Mounting Position: Any ! Marking: Type Number Case: DO-201AD, Molded Plastic Mechanical Data DO-201AD Dim Min Max A 25.40 : B 7.20 9.50 C 1.20 1.30 D 4.80 5.30 All Dimensions in mm A B A C D F
