Designed for use in solid state relays, MPU interface, TTL logic and any other light industrial or consumer application. Supplied in an inexpensive TO−92 package which is readily adaptable for use in automatic insertion equipment.
• One−Piece, Injection−Molded Package • Blocking Voltage to 600 Volts • Sensitive Gate Triggering in Four Trigger Modes (Quadrants) for all possible Combinations of Trigger Sources, and especially for Circuits that Source Gate Drives • All Diffused and Glassivated Junctions for Maximum Uniformity of Parameters and Reliability • Pb−Free Packages are Available*
