东芝BICD集成电路硅单片tb67s109afnag
消耗积分:0 | 格式:pdf | 大小:1093KB | 2017-10-21
马钰人
分享资料个
TB67S109AFNAG_160115
  The TB67S109A is a two-phase bipolar stepping motor driver using a PWM chopper. The clock in decoder is built in. Fabricated with the BiCD process, rating is 50 V/4.0 A 。
  ・BiCD process integrated monolithic IC. ・Capable of controlling 1 bipolar stepping motor. ・PWM controlled constant-current drive. ・Allows full, half, quarter, 1/8, 1/16, 1/32 step operation. ・Low on-resistance (High + Low side=0.49Ω(typ.)) MOSFET output stage. ・High efficiency motor current control mechanism (Advanced Dynamic Mixed Decay) ・High voltage and current (For specification, please refer to absolute maximum ratings and operation ranges) ・Error detection (TSD/ISD) signal output function ・Built-in error detection circuits (Thermal shutdown (TSD)、over-current shutdown (ISD), and power-on reset (POR)) ・Built-in VCC regulator for internal circuit use. ・Chopping frequency of a motor can be customized by external resistance and capacitor. ・Multi package lineup TB67S109AFNAG: HSSOP36 Note) Please be careful about thermal conditions during use.
评论(1)
发评论
CHIPSPOWER-Anne 2022-10-30
0 回复 举报
谢谢分享资料TB67S109AFNAG 收起回复
下载排行榜
全部1条评论
