OPTOELECTRONICS CIRCUIT COLLECTION
AVALANCHE PHOTODIODE BIAS SUPPLY 1
Provides an output voltage of 0V to +80V for reverse biasing
an avalanche photodiode to control its gain. This circuit can
also be reconfigured to supply a 0V to –80V output.
LINEAR TEC DRIVER–1
This is a bridge-tied load (BTL) linear amplifier for driving
a thermoelectric cooler (TEC). It operates on a single +5V
supply and can drive ±2A into a common TEC.
LINEAR TEC DRIVER–2
This is very similar to DRIVER–1 but its power output stage
was modified to operate from a single +3.3V supply in order
to increase its efficiency. Driving this amplifier from a
standard +2.5V referenced signal causes the output transistors
to have unequal power dissipation.
LINEAR TEC DRIVER–3
This BTL TEC driver power output stage achieves very high
efficiency by swinging very close to its supply rails, ±2.5V.
This driver can also drive ±2A into a common TEC. Operation
is shown with the power output stage operating on
±1.5V supplies. Under these conditions, this linear amplifier
can achieve very high efficiency.
Application Report
The following collection of analog circuits may be useful in electro-optics applications such as optical networking
systems. This page summarizes their salient characteristics.
全部2条评论
