#include《reg52.h》
#include 《intrins.h》 //方便调用空指令
#include《math.h》
#define uchar unsigned char
void DelayUs2x(unsigned char t); //延时
void DelayMs(unsigned char t);
/************* 写文字的定义 *********************/
#define uint unsigned int
sbit SI = P0^0;//clock input同步时钟输入端
sbit SCL = P0^1;//data input/output串行数据输入、输出端
sbit A0 = P0^2;//选择命令还是数据
sbit RST = P0^3;//复位
sbit CS = P0^4;//片选
uchar code BMP[]=
//字库intrins.h
/*-- 文字: 。 --*/
/*-- Fixedsys12; 此字体下对应的点阵为:宽x高=8x16 --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0x0C,0x0C,0x00,0x00,
/*-- 文字: : --*/
0x00,0x00,0x00,0x60,0x60,0x60,0x00,0x00,0x00,0x00,0x00,0x0C,0x0C,0x0C,0x00,0x00,
/*-- 文字: --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*-- 文字: A --*/
0x00,0xE0,0xF0,0x18,0x18,0xF0,0xE0,0x00,0x00,0x0F,0x0F,0x01,0x01,0x0F,0x0F,0x00,
/*-- 文字: F --*/
0x00,0xF8,0xF8,0x88,0x88,0x88,0x08,0x00,0x00,0x0F,0x0F,0x00,0x00,0x00,0x00,0x00,
/*-- 文字: V --*/
0x00,0xF8,0xF8,0x00,0x00,0xF8,0xF8,0x00,0x00,0x03,0x07,0x0C,0x0C,0x07,0x03,0x00,
/*-- 文字: H --*/
0x00,0xF8,0xF8,0x80,0x80,0xF8,0xF8,0x00,0x00,0x0F,0x0F,0x00,0x00,0x0F,0x0F,0x00,
/*-- 文字: e --*/
0x00,0xC0,0xE0,0x20,0x20,0xE0,0xC0,0x00,0x00,0x07,0x0F,0x09,0x09,0x09,0x01,0x00,
/*-- 文字: k --*/
0x00,0xF8,0xF8,0x00,0x80,0xE0,0x60,0x00,0x00,0x0F,0x0F,0x01,0x03,0x0E,0x0C,0x00,
/*-- 文字: m --*/
0x00,0xE0,0xE0,0x20,0xE0,0x20,0xE0,0xC0,0x00,0x0F,0x0F,0x00,0x07,0x00,0x0F,0x0F,
/*-- 文字: p --*/
0x00,0xE0,0xE0,0x20,0x20,0xE0,0xC0,0x00,0x00,0x7F,0x7F,0x08,0x08,0x0F,0x07,0x00,
