AAT4702,pdf datasheet(Auto-Res
消耗积分:2 | 格式:rar | 大小:221 | 2010-01-29
王杰
分享资料个
The AAT4702 SmartSwitch™ is a member of AnalogicTech’s Application Specific Power MOSFET™ (ASPM™) product family. This device integrates a high side P-channel
MOSFET current limiting load switch with a nanopower low dropout (LDO) linear voltage regulator, making the AAT4702 ideal for use in load current protected applications that also require a system power supply. The load switch operates with input voltages ranging from 2.4V to 5.5V, making it ideal for 2.5V, 3V, and 5V systems. A fault flag is provided to alert the system to an overcurrent event. The fault flag has a 5ms blanking time to prevent from reporting false events such as inrush currents during system startup.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
