UCOS移植在MCU8051 LARGE模式的源代码下载
消耗积分:10 | 格式:rar | 大小:186 | 2010-02-24
分享资料个
C51 COMPILER V7.50   OS_SEM        05/17/2007 19:18:11 PAGE 1
C51 COMPILER V7.50, COMPILATION OF MODULE OS_SEM
OBJECT MODULE PLACED IN .\OS_SEM.obj
COMPILER INVOKED BY: d:\Keil\C51\BIN\C51.EXE ..\UCOS_II\OS_SEM.C LARGE BROWSE DEBUG OBJECTEXTEND PRINT(.\OS_SEM.lst) OBJ
                    -ECT(.\OS_SEM.obj)
line level    source
   1          /*
   2         *************************************************************
   3          *                                                uC/OS-II
   4          *                                          The Real-Time Kernel
   5          *                                          SEMAPHORE MANAGEMENT
   6          *
   7          *                          (c) Copyright 1992-2002, Jean J. Labrosse, Weston, FL
   8          *                                           All Rights Reserved
   9          *
  10          * File : OS_SEM.C
  11          * By   : Jean J. Labrosse
  12          ***********************************************************
  13          */
  14
  15          #ifndef  OS_MASTER_FILE
  16          #include "includes.h"
  17          #endif
  18
  19          #if OS_SEM_EN > 0
              *                                           ACCEPT SEMAPHORE
              * Description: This function checks the semaphore to see if a resource is available or, if an event
              *              occurred.  Unlike OSSemPend(), OSSemAccept() does not suspend the calling task if the
              *              resource is not available or the event did not occur.
              * Arguments  : pevent     is a pointer to the event control block
              * Returns    : >  0       if the resource is available or the event did not occur the semaphore is
              *                         decremented to obtain the resource.
              *              == 0       if the resource is not available or the event did not occur or,
              *                         if 'pevent' is a NULL pointer or,
              *                         if you didn't pass a pointer to a semaphore
              #if OS_SEM_ACCEPT_EN > 0
              INT16U  OSSemAccept (OS_EVENT xdata *pevent)reentrant
              #if OS_CRITICAL_METHOD == 3                           /* Allocate storage for CPU status register      */
                  OS_CPU_SR  cpu_sr;
              #endif
                  INT16U     cnt;
              #if OS_ARG_CHK_EN > 0
                  if (pevent == (OS_EVENT *)0) {                    /* Validate 'pevent'                             */
                      return (0);
                  if (pevent->OSEventType != OS_EVENT_TYPE_SEM) {   /* Validate event block type                     */
                      return (0);
              #endif
C51 COMPILER V7.50   OS_SEM        05/17/2007 19:18:11 PAGE 2
                  OS_ENTER_CRITICAL();
                  cnt = pevent->OSEventCnt;
                  if (cnt > 0) {                                    /* See if resource is available                  */
                      pevent->OSEventCnt--;                         /* Yes, decrement semaphore and notify caller    */
                  OS_EXIT_CRITICAL();
                  return (cnt);                                     /* Return semaphore count                        */
              #endif
              /*$PAGE*/
              *                                           CREATE A SEMAPHORE
              * Description: This function creates a semaphore.
              * Arguments  : cnt           is the initial value for the semaphore.  If the value is 0, no resource is
              *                            available (or no event has occurred).  You initialize the semaphore to a
              *                            non-zero value to specify how many resources are available (e.g. if you have
              *                            10 resources, you would initialize the semaphore to 10).
              * Returns    : != (void *)0  is a pointer to the event control clock (OS_EVENT) associated with the
              *                            created semaphore
              *              == (void *)0  if no event control blocks were available
              OS_EVENT xdata *OSSemCreate (INT16U cnt)reentrant
                  OS_CPU_SR  cpu_sr;
              #endif
                  OS_EVENT xdata *pevent;
                  if (OSIntNesting > 0) {                                /* See if called from ISR ...               */
                      return ((OS_EVENT *)0);                            /* ... can't CREATE from an ISR             */
                  pevent = OSEventFreeList;                              /* Get next free event control block        */
                  if (OSEventFreeList != (OS_EVENT *)0) {                /* See if pool of free ECB pool was empty   */
                      OSEventFreeList = (OS_EVENT *)OSEventFreeList->OSEventPtr;
                  OS_EXIT_CRITICAL();
                  if (pevent != (OS_EVENT *)0) {                         /* Get an event control block               */
                      pevent->OSEventType = OS_EVENT_TYPE_SEM;
                      pevent->OSEventCnt  = cnt;                         /* Set semaphore value                      */
                      pevent->OSEventPtr  = (void *)0;                   /* Unlink from ECB free list                */
                      OS_EventWaitListInit(pevent);                      /* Initialize to 'nobody waiting' on sem.   */
                  return (pevent);
              /*$PAGE*/
              *                                         DELETE A SEMAPHORE
              * Description: This function deletes a semaphore and readies all tasks pending on the semaphore.
              * Arguments  : pevent        is a pointer to the event control block associated with the desired
C51 COMPILER V7.50   OS_SEM        05/17/2007 19:18:11 PAGE 3
              *                            semaphore.
              *              opt           determines delete options as follows:
              *                            opt == OS_DEL_NO_PEND   Delete semaphore ONLY if no task pending
              *                            opt == OS_DEL_ALWAYS    Deletes the semaphore even if tasks are waiting.
              *                                                    In this case, all the tasks pending will be readied.
              *              err           is a pointer to an error code that can contain one of the following values:
              *                            OS_NO_ERR               The call was successful and the semaphore was deleted
              *                            OS_ERR_DEL_ISR          If you attempted to delete the semaphore from an ISR
              *                            OS_ERR_INVALID_OPT      An invalid option was specified
              *                            OS_ERR_TASK_WAITING     One or more tasks were waiting on the semaphore
              *                            OS_ERR_EVENT_TYPE       If you didn't pass a pointer to a semaphore
              *                            OS_ERR_PEVENT_NULL      If 'pevent' is a NULL pointer.
              * Returns    : pevent        upon error
              *              (OS_EVENT *)0 if the semaphore was successfully deleted.
              * Note(s)    : 1) This function must be used with care.  Tasks that would normally expect the presence of
              *                 the semaphore MUST check the return code of OSSemPend().
              *              2) OSSemAccept() callers will not know that the intended semaphore has been deleted unless
              *                 they check 'pevent' to see that it's a NULL pointer.
              *              3) This call can potentially disable interrupts for a long time.  The interrupt disable
              *                 time is directly proportional to the number of tasks waiting on the semaphore.
              *              4) Because ALL tasks pending on the semaphore will be readied, you MUST be careful in
              *                 applications where the semaphore is used for mutual exclusion because the resource(s)
              *                 will no longer be guarded by the semaphore.
              #if OS_SEM_DEL_EN > 0
              OS_EVENT xdata  *OSSemDel (OS_EVENT xdata*pevent, INT8U opt, INT8U xdata *err)reentrant
                  OS_CPU_SR  cpu_sr;
              #endif
                  BOOLEAN    tasks_waiting;
                      *err = OS_ERR_DEL_ISR;                             /* ... can't DELETE from an ISR             */
                      return (pevent);
                      *err = OS_ERR_PEVENT_NULL;
                      return (pevent);
                      *err = OS_ERR_EVENT_TYPE;
                      return (pevent);
              #endif
                  if (pevent->OSEventGrp != 0x00) {                      /* See if any tasks waiting on semaphore    */
                      tasks_waiting = TRUE;                              /* Yes                                      */
                  } else {
                      tasks_waiting = FALSE;                             /* No                                       */
                  switch (opt) {
                      case OS_DEL_NO_PEND:                               /* Delete semaphore only if no task waiting */
                           if (tasks_waiting == FALSE) {
C51 COMPILER V7.50   OS_SEM        05/17/2007 19:18:11 PAGE 4
                               pevent->OSEventType = OS_EVENT_TYPE_UNUSED;
                               pevent->OSEventPtr  = OSEventFreeList;    /* Return Event Control Block to free list  */
                               OSEventFreeList     = pevent;             /* Get next free event control block        */
                               OS_EXIT_CRITICAL();
                               *err = OS_NO_ERR;
                               return ((OS_EVENT *)0);                   /* Semaphore has been deleted               */
                           } else {
                               OS_EXIT_CRITICAL();
                               *err = OS_ERR_TASK_WAITING;
                               return (pevent);
                      case OS_DEL_ALWAYS:                                /* Always delete the semaphore              */
                           while (pevent->OSEventGrp != 0x00) {          /* Ready ALL tasks waiting for semaphore    */
                               OS_EventTaskRdy(pevent, (void *)0, OS_STAT_SEM);
                           OS_EXIT_CRITICAL();
                           if (tasks_waiting == TRUE) {                  /* Reschedule only if task(s) were waiting  */
                               OS_Sched();                               /* Find highest priority task ready to run  */
                           *err = OS_NO_ERR;
                      default:
                           OS_EXIT_CRITICAL();
                           *err = OS_ERR_INVALID_OPT;
                           return (pevent);
              #endif
              /*$PAGE*/
              *                                           PEND ON SEMAPHORE
              * Description: This function waits for a semaphore.
              *                            semaphore.
              *              timeout       is an optional timeout period (in clock ticks).  If non-zero, your task will
              *                            wait for the resource up to the amount of time specified by this argument.
              *                            If you specify 0, however, your task will wait forever at the specified
              *                            semaphore or, until the resource becomes available (or the event occurs).
              *              err           is a pointer to where an error message will be deposited.  Possible error
              *                            messages are:
              *                            OS_NO_ERR           The call was successful and your task owns the resource
              *                                                or, the event you are waiting for occurred.
              *                            OS_TIMEOUT          The semaphore was not received within the specified
              *                                                timeout.
              *                            OS_ERR_EVENT_TYPE   If you didn't pass a pointer to a semaphore.
              *                            OS_ERR_PEND_ISR     If you called this function from an ISR and the result
              *                                                would lead to a suspension.
              * Returns    : none
C51 COMPILER V7.50   OS_SEM        05/17/2007 19:18:11 PAGE 5
              void  OSSemPend (OS_EVENT xdata *pevent, INT16U timeout, INT8U xdata *err)reentrant
                  OS_CPU_SR  cpu_sr;
              #endif
                      *err = OS_ERR_PEND_ISR;                       /* ... can't PEND from an ISR                    */
                      return;
                      return;
                      return;
              #endif
                  if (pevent->OSEventCnt > 0) {                     /* If sem. is positive, resource available ...   */
                      pevent->OSEventCnt--;                         /* ... decrement semaphore only if positive.     */
                      OS_EXIT_CRITICAL();
                      *err = OS_NO_ERR;
                      return;
        /* Otherwise, must wait until event occurs       */
                  OSTCBCur->OSTCBStat |= OS_STAT_SEM;               /* Resource not available, pend on semaphore     */
                  OSTCBCur->OSTCBDly   = timeout;                   /* Store pend timeout in TCB                     */
                  OS_EventTaskWait(pevent);                         /* Suspend task until event or timeout occurs    */
                  OS_EXIT_CRITICAL();
                  OS_Sched();                                       /* Find next highest priority task ready         */
                  if (OSTCBCur->OSTCBStat & OS_STAT_SEM) {          /* Must have timed out if still waiting for event*/
                      OS_EventTO(pevent);
                      OS_EXIT_CRITICAL();
                      *err = OS_TIMEOUT;                            /* Indicate that didn't get event within TO      */
                      return;
                  OSTCBCur->OSTCBEventPtr = (OS_EVENT *)0;
                  OS_EXIT_CRITICAL();
                  *err = OS_NO_ERR;
              /*$PAGE*/
              *                                         POST TO A SEMAPHORE
              * Description: This function signals a semaphore
              *                            semaphore.
              * Returns    : OS_NO_ERR           The call was successful and the semaphore was signaled.
              *              OS_SEM_OVF          If the semaphore count exceeded its limit.  In other words, you have
              *                                  signalled the semaphore more often than you waited on it with either
              *                                  OSSemAccept() or OSSemPend().
C51 COMPILER V7.50   OS_SEM        05/17/2007 19:18:11 PAGE 6
              INT8U  OSSemPost (OS_EVENT xdata *pevent)reentrant
                  OS_CPU_SR  cpu_sr;
              #endif
                      return (OS_ERR_PEVENT_NULL);
                      return (OS_ERR_EVENT_TYPE);
              #endif
                  if (pevent->OSEventGrp != 0x00) {                      /* See if any task waiting for semaphore    */
                      OS_EventTaskRdy(pevent, (void *)0, OS_STAT_SEM);   /* Ready highest prio task waiting on event */
                      OS_EXIT_CRITICAL();
                      return (OS_NO_ERR);
                  if (pevent->OSEventCnt < 65535) {                 /* Make sure semaphore will not overflow         */
                      pevent->OSEventCnt++;                         /* Increment semaphore count to register event   */
                      OS_EXIT_CRITICAL();
                      return (OS_NO_ERR);
                  OS_EXIT_CRITICAL();                               /* Semaphore value has reached its maximum       */
                  return (OS_SEM_OVF);
              /*$PAGE*/
              *                                          QUERY A SEMAPHORE
              * Description: This function obtains information about a semaphore
              *                            semaphore
              *              pdata         is a pointer to a structure that will contain information about the
              *                            semaphore.
              * Returns    : OS_NO_ERR           The call was successful and the message was sent
              *              OS_ERR_EVENT_TYPE   If you are attempting to obtain data from a non semaphore.
              #if OS_SEM_QUERY_EN > 0
              INT8U  OSSemQuery (OS_EVENT xdata *pevent, OS_SEM_DATA xdata *ppdata)reentrant
                  OS_CPU_SR  cpu_sr;
              #endif
                  INT8U  xdata   *psrc;
                  INT8U  xdata   *pdest;
C51 COMPILER V7.50   OS_SEM        05/17/2007 19:18:11 PAGE 7
              #endif
                  ppdata->OSEventGrp = pevent->OSEventGrp;                /* Copy message mailbox wait list           */
                  psrc              = &pevent->OSEventTbl[0];
                  pdest             = &ppdata->OSEventTbl[0];
              #if OS_EVENT_TBL_SIZE > 0
                  *pdest++          = *psrc++;
              #endif
              #if OS_EVENT_TBL_SIZE > 1
                  *pdest++          = *psrc++;
              #endif
              #if OS_EVENT_TBL_SIZE > 2
                  *pdest++          = *psrc++;
              #endif
              #if OS_EVENT_TBL_SIZE > 3
                  *pdest++          = *psrc++;
              #endif
              #if OS_EVENT_TBL_SIZE > 4
                  *pdest++          = *psrc++;
              #endif
              #if OS_EVENT_TBL_SIZE > 5
                  *pdest++          = *psrc++;
              #endif
              #if OS_EVENT_TBL_SIZE > 6
                  *pdest++          = *psrc++;
              #endif
              #if OS_EVENT_TBL_SIZE > 7
                  *pdest            = *psrc;
              #endif
                  ppdata->OSCnt     = pevent->OSEventCnt;                /* Get semaphore count                      */
                  OS_EXIT_CRITICAL();
                  return (OS_NO_ERR);
              #endif                                                     /* OS_SEM_QUERY_EN                          */
              #endif                                                     /* OS_SEM_EN                                */
MODULE INFORMATION:   STATIC OVERLAYABLE
   CODE SIZE        =   ----    ----
   CONSTANT SIZE    =   ----    ----
   XDATA SIZE       =   ----    ----
   PDATA SIZE       =   ----    ----
   IDATA SIZE       =   ----    ----
   BIT SIZE         =   ----    ----
END OF MODULE INFORMATION.
C51 COMPILER V7.50   OS_SEM        05/17/2007 19:18:11 PAGE 8
C51 COMPILATION COMPLETE.  0 WARNING(S),  0 ERROR(S)
评论(0)
发评论
下载排行榜
