微星 845GEM-V主板英文版说明书
消耗积分:0 | 格式:rar | 大小:1184 | 2010-04-06
ty880@163.com
分享资料个
微星 845GEM-V主板英文版说明书
FCC-B Radio Frequency Interference Statement
This equipment has been tested and found to comply with the limits for a class B digital device, pursuant to part 15 of
the FCC rules. These limits are designed to provide reasonable protection against harmful interference when the
equipment is operated in a commercial environment. This equipment generates, uses and can radiate radio frequency
energy and, if not installed and used in accordance with the instruction manual, may cause harmful interference to
radio communications. Operation of this equipment in a residential area is likely to cause harmful interference, in
which case the user will be required to correct the interference at his own expense.
评论(0)
发评论
下载排行榜
