SRC4190,pdf(192kHz Stereo Asyn
消耗积分:3 | 格式:rar | 大小:1285 | 2010-06-11
分享资料个
The SRC4190 is an asychronous sample rate converter designed for professional and broadcast audio applications. The SRC4190 combines a wide input-to-output sampling ratio with outstanding dynamic range and low distortion. Input and output serial ports support standard audio formats, as well as a Time Division Multiplexed (TDM) mode. Flexible audio interfaces allow the SRC4190 to connect to a wide range of audio data converters, digital audio receivers and transmitters, and digital signal processors.
The SRC4190 is a standalone pin-programmed device, with control pins for mode, data format, mute, bypass, and low group delay functions.
The SRC4190 may be operated from a single +3.3V power supply. A separate digital I/O supply (VIO) operates over the +1.
评论(0)
发评论
下载排行榜
