PCM3501,pdf(Low Voltage, Low P
消耗积分:3 | 格式:rar | 大小:378 | 2010-06-23
laisvl
分享资料个
DESCRIPTION
The PCM3501 is a low cost, 16-bit CODEC designed
for modem Analog Front End (AFE) and speech processing
applications. The PCM3500’s low power operation
from +2.7V to +3.6V power supplies, along
with an integrated power-down mode, make it ideal for
portable applications.
The PCM3501 integrates all of the functions needed for
a modem or voice CODEC, including delta-sigma
digital-to-analog and analog-to-digital converters, input
anti-aliasing filter, digital high-pass filter for DC
blocking, and an output low-pass filter. The synchronous
serial interface provides for a simple, or glue-free
interface to popular DSP and RISC processors. The
serial interface also supports Time Division Multiplexing
(TDM), allowing up to four CODECs to share a
single 4-wire serial bus.
评论(0)
发评论
下载排行榜
