在电子工程领域,MOSFET(金属 - 氧化物 - 半导体场效应晶体管)是一种至关重要的电子元件,广泛应用于各种电路设计中。今天,我们将深入探讨Fairchild(现属ON Semiconductor)的FDMS86202 N-Channel Shielded Gate PowerTrench® MOSFET,了解它的特点、性能参数以及应用场景。
文件下载:FDMS86202-D.pdf
Fairchild已成为ON Semiconductor的一部分。由于系统要求,部分Fairchild可订购的产品编号需要更改,原编号中的下划线(_)将改为破折号(-)。大家可访问ON Semiconductor的网站(www.onsemi.com)核实更新后的设备编号。若对系统集成有疑问,可发邮件至Fairchild_questions@onsemi.com。
FDMS86202采用了Shielded Gate MOSFET技术,结合了先进的PowerTrench®工艺。这种工艺在优化导通电阻的同时,还能保持出色的开关性能。
在 (V{GS}=10 V),(I{D}=13.5 A) 时,最大 (r{DS(on)}=7.2 mΩ);在 (V{GS}=6 V),(I{D}=11.5 A) 时,最大 (r{DS(on)}=10.3 mΩ)。先进的封装和硅片组合,实现了低导通电阻和高效率。
采用MSL1稳健封装设计,并且经过100% UIL测试,符合RoHS标准。
FDMS86202适用于DC - DC转换电路。在这种电路中,其低导通电阻和良好的开关性能能够有效提高转换效率,减少能量损耗。
| Symbol | Parameter | Ratings | Units |
| (V_{DS}) | Drain to Source Voltage | 120 | V |
| (V_{GS}) | Gate to Source Voltage | ±20 | V |
| (I_{D}) | Drain Current - Continuous ((T_{C} = 25 °C)) | 64 | A |
| (I_{D}) | Drain Current - Continuous ((T_{A} = 25 °C)) | 13.5 | A |
| (I_{D}) | Drain Current - Pulsed | 240 | A |
| (E_{AS}) | Single Pulse Avalanche Energy | 600 | mJ |
| (P_{D}) | Power Dissipation ((T_{C} = 25 °C)) | 156 | W |
| (P_{D}) | Power Dissipation ((T_{A} = 25 °C)) | 2.7 | W |
| (T{J}, T{STG}) | Operating and Storage Junction Temperature Range | -55 to +150 | °C |
| (R_{θJC}) | Thermal Resistance, Junction to Case | 0.8 | °C/W |
| (R_{θJA}) | Thermal Resistance, Junction to Ambient | 45 | °C/W |
| (BV_{DSS}) | Drain to Source Breakdown Voltage | 120 | V |
| (frac{Delta BV{DSS}}{Delta T{J}}) | Breakdown Voltage Temperature Coefficient | 103 | mV/°C |
| (I_{DSS}) | Zero Gate Voltage Drain Current | 1 | μA |
| (I_{GSS}) | Gate to Source Leakage Current | ±100 | nA |
| (V_{GS(th)}) | Gate to Source Threshold Voltage | 2.0 - 4.0 | V |
| (frac{Delta V{GS(th)}}{Delta T{J}}) | Gate to Source Threshold Voltage Temperature Coefficient | -10 | mV/°C |
| (r_{DS(on)}) | Static Drain to Source On Resistance | 6.0 - 13.2 | mΩ |
| (g_{FS}) | Forward Transconductance | 44 | S |
| (C_{iss}) | Input Capacitance | 3195 - 4250 | pF |
| (C_{oss}) | Output Capacitance | 449 - 600 | pF |
| (C_{rss}) | Reverse Transfer Capacitance | 17 - 30 | pF |
| (R_{g}) | Gate Resistance | 0.1 - 2.7 | Ω |
| (t_{d(on)}) | Turn - On Delay Time | 21 | ns |
| (t_{r}) | Rise Time | 13 | ns |
| (t_{d(off)}) | Turn - Off Delay Time | 44 | ns |
| (t_{f}) | Fall Time | 11 | ns |
| (Q_{g}) | Total Gate Charge | 33 - 64 | nC |
| (V_{SD}) | Source to Drain Diode Forward Voltage | 0.69 - 1.3 | V |
| (t_{rr}) | Reverse Recovery Time | 73 - 118 | ns |
| (Q_{rr}) | Reverse Recovery Charge | 117 - 187 | nC |
文档中给出了多个典型特性曲线,这些曲线直观地展示了FDMS86202在不同条件下的性能表现。例如,导通区域特性曲线展示了不同 (V{GS}) 下,漏极电流 (I{D}) 与漏源电压 (V_{DS}) 的关系;归一化导通电阻与漏极电流和栅极电压的关系曲线,有助于工程师了解导通电阻在不同工作条件下的变化情况。
| Device Marking | Device | Package | Reel Size | Tape Width | Quantity |
| FDMS86202 | FDMS86202 | Power 56 | 13 ’’ | 12 mm | 3000 units |
ON Semiconductor保留对产品进行更改的权利,且不承担产品用于特定目的的适用性保证,也不承担因产品应用或使用产生的任何责任。同时,该产品不适合用于生命支持系统、FDA Class 3医疗设备等特定应用。
作为电子工程师,在选择和使用FDMS86202 MOSFET时,我们需要充分了解其特点和性能参数,结合具体的应用场景进行合理设计。大家在实际应用中遇到过哪些与MOSFET相关的问题呢?欢迎在评论区分享交流。
