This document describes software examples for the CC2430 System-on-Chip solution for IEEE 802.15.4/ZigBee. It also describes the necessary hardware and software to run the examples, and how to get started. The software examples are able to run on the CC2430EM or CC2430_CC2590- 91EM with either CC2590 or CC2591, mounted on SmartRF04EB.
Section 3 of this document describes necessary prerequisites and how to get started with the code examples. Section 4 describes how to run each of the application examples. The software library that the code examples are built upon is described in section 5. The latter section also gives an API reference and describes the functionality of the software library. Hex files for each of the example applications are provided. IAR EW Full version is needed for building the source code.
