About user’s guides Your machine is packaged with two user guides: • This user’s guide, which provides you with information on installing the supplied CD-ROM to use your machine as a printer and scanner. This guide also provides the basic description on using the supplied multi-function application programme, Samsung SmarThru, which allows you to scan and edit images, send E-mail and PC-fax. You will also find a brief description on automatic text recognition programme, AnyPage Lite. • Laser facsimile user’s guide, which provides you with all of the detailed information you will need to install, send and receive a fax, maintain and troubleshoot your machine.
