ISO7420,ISO7420M,ISO7421,ISO74
消耗积分:5 | 格式:rar | 大小:476 | 2010-08-26
向日葵的花季
分享资料个
The ISO7420, ISO7420M, ISO7421, and ISO7421M provide galvanic isolation up to 2.5 kVrms for 1 minute per UL. These digital isolators have two isolated channels. Each isolation channel has a logic input and output buffer separated by a silicon dioxide (SiO2) insulation barrier. Used in conjunction with isolated power supplies, these devices prevent noise currents on a data bus or other circuit from entering the local ground and interfering with or damaging sensitive circuitry. The suffix M indicates wide temperature range (–40°C to 125°C).
The devices have TTL input thresholds and require two supply voltages, 3.3V or 5V, or any combination. All inputs are 5-V tolerant when supplied from a 3.
评论(0)
发评论
下载排行榜
