SL811开发资料_包含源程序_电路图_芯片资料
消耗积分:10 | 格式:rar | 大小:433 | 2010-10-02
31274
分享资料个
SL811开发资料_包含源程序_电路图_芯片资料:SL811HS Embedded USB Host/Slave Controller.The SL811HS is an Embedded USB Host/Slave Controller capable of communicate with either full-speed or low-speed USB peripherals. The SL811HS can interface to devices such as microprocessors, microcontrollers, DSPs, or directly to a variety of buses such as ISA, PCMCIA, and others. The SL811HS USB Host Controller conforms to USB Specification 1.1.The SL811HS USB Host/Slave Controller incorporates USB Serial Interface functionality along with internal full-/low-speed transceivers.The SL811HS supports and operates in USB full-speed mode at 12 Mbps, or at low-speed 1.5-Mbps mode.The SL811HS data port and microprocessor interface provide an 8-bit data path I/O or DMA bidirectional, with interrupt support to allow easy interface to standard microprocessors or microcontrollers such as Motorola or Intel CPUs and many others. Internally,the SL811HS contains a 256-byte RAM data buffer which is used for control registers and data buffer.The available package types offered are a 28-pin PLCC (SL811HS) and a 48-pin TQFP package (SL811HST-AC). Both packages operate at 3.3 VDC. The I/O interface logic is 5V-tolerant.
评论(5)
发评论
┌透明雨┐ 2017-01-19
0 回复 举报
大大的赞 收起回复
绿止冰崖 2016-06-21
0 回复 举报
好资料,赞一个 收起回复
全部评论
下载排行榜
全部5条评论
