On the LPC13xx, programming, erasure and re-programming of the on-chip flash can be performed using In-System Programming (ISP) via the UART serial port, and also, can be performed using In-Application Programming (IAP) calls directed by the end-user code. For In-System Programming (ISP) via the UART serial port, the ISP command handler (resides in the bootloader) allows erasure of one or more sector (s) of the on-chip flash memory.
