1 FEATURES · Single chip LCD controller/driver · 1 or 2-line display of up to 24 characters per line, or 2 or 4 lines of up to 12 characters per line · 5 ′ 7 character format plus cursor; 5 ′ 8 for kana (Japanese syllabary) and user defined symbols · On-chip: – generation of LCD supply voltage (external supply also possible) – generation of intermediate LCD bias voltages – oscillator requires no external components (external clock also possible) · Display data RAM: 80 characters · Character generator ROM: 240 characters · Character generator RAM: 16 characters · 4 or 8-bit parallel bus or 2-wire I2C-bus interface · CMOS/TTL compatible · 32 row, 60 column outputs · MUX rates 1 : 32 and 1 : 16 · Uses common 11 code instruction set · Logic supply voltage range, VDD - VSS: 2.5 to 6 V · Display supply voltage range, VDD - VLCD: 3.5 to 9 V · Low power consumption · I2C-bus address: 011101 SA0.
