基于Multisim 10的矩形波信号发生器仿真与实现
消耗积分:10 | 格式:rar | 大小:1187 | 2010-11-22
丁冬芹
分享资料个
在Multisim 10软件环境下,设计一种由运算放大器构成的精确可控矩形波信号发生器,结合系统电路原理图重点阐述了各参数指标的实现与测试方法。通过改变RC电路的电容充、放电路径和时间常数实现了占空比和频率的调节,通过多路开关投入不同数值的电容实现了频段的调节,通过电压取样和同相放大电路实现了输出电压幅值的调节并提高了电路的带负载能力,可作为频率和幅值可调的方波信号发生器。Multisim 10仿真分析及应用电路测试结果表明,电路性能指标达到了设计要求。
Abstract:
 Based on Multisim 10, this paper designed a kind of rectangular-wave signal generator which could be controlled exactly composed of operational amplifier, the key point was how to implement and test the parameter indicators based on the circuit diagram. The duty and the frequency were adjusted by changing the time constant and the way of charging and discharging of the capacitor, the width of frequency was adjusted by using different capacitors provided with multiple switch, the amplitude of output voltage was adjusted by sampling voltage and using in-phase amplifier circuit,the ability of driving loads was raised, the circuit can be used as squarewave signal generator whose frequency and amplitude can be adjusted. The final simulation results of Multisim 10 and the tests of applicable circuit show that the performance indicators of the circuit meets the design requirements.
评论(1)
发评论
dhdf 2011-09-04
1 回复 举报
资料是知识,当然好,但不知是否中文。 收起回复
下载排行榜
全部1条评论
