MSI微星 H55MA-E43主板
消耗积分:10 | 格式:rar | 大小:2670 | 2010-11-24
分享资料个
MSI微星 H55MA-E43主板
主板驱动程序
Award BIOS Flash Procedure
1. Know your model number
a. Open your case and look for the MS-XXXX number on the motherboard between the PCI slots, also check the version number that is written there as well. (Some motherboards are named like K8N Diamond; make sure you have the right version number)
b. Boot up your system & take a look at the top left screen during POST, you should see something like “W7100NMS V1.1 021705” This means the board is MS-7100 with BIOS version 1.1
Hint: Many systems are clearing this message very fast, the bios version is then unreadable, and you can either press “PAUSE” or disable the “Quick Boot” in the BIOS setup.
2. Download the BIOS that matches your motherboard AND version number (some motherboards are named like K8N Diamond; make sure you have the right version number). BIOS can be found according to the CPU type of your board like if your CPU is AMD 939 type then look here
评论(0)
发评论
下载排行榜
