介绍一种基于单片机的多路温度采集及监控系统,能够测量6路温度信号,具有计算机联网功能,各测量点可以单独监控和设置,可根据用户的需求自动控制。测量温度范围为-10 ℃~200 ℃,控制方式采用模拟量调压模式。该系统具有控制精度高、冲击小等特点。
- Abstract:
- A temperature collecting and surveillance-controlling system based on sing-chip microcomputer is introduced. It can measure 6 channel signal of the temperature,and it has a function of network connection.The temperature measure points can be monitored and located, it can be controlled automatic according to user’s demand.The temperature range is -10℃ to 200℃.The model of control is adjustable voltage with simulation. It features high precision and little impact.
