Mega16是一款采用先进RISC精简指令,内置A/D的8位单片机,可支持低电压联机 Flash和EEPROM 写入功能;同时还支持 Basic和C 等高级语言编程。用它设计电子时钟不仅成本低,硬件简单,而且很容易实现系统移植。介绍了如何利用AVR系列单片机Mega16及1602字符液晶来设计电子时钟的方法,同时给出了相应的电路原理及部分语言程序。
- Abstract:
- ?Mega16 is a high-performance, low power consumption, the use of advanced RISC concise instructions, built-in A/D 8-bit microcontrollers, the on-line support for low-voltage Flash, EEPROM write function. Except Mega16 also support the Basic, C, and other high-level language programming.The electronic clock which is deisgned by Mega16 is not only low-cost, simple hardware, but easy to achieve system migration.The design method of electrioic clock based on the AVR Mega16 and character LCD1602 is introduced in this paper,and the corresponding circuit electrionic and some language program are given.
