基于8051F单片机的数字音频信号源的幅度控制
消耗积分:5 | 格式:rar | 大小:780 | 2010-12-20
张磊
分享资料个
介绍一种基于8051F单片机的数字音频信号源,利用单片机用DDS算法产生音频信号,通过数字电阻衰减器控制音频信号幅度,在0~100 dB的幅度范围内实现1 dB的步进值,系统计算机接口实现了集中多路衰减量的控制。
Abstract:
 A kind of digital audio signal source based on C8051F is introduced in this paper.Audio signal is produced with DDS algorithm by using C8051F330 and the audio signal amplitude is controlled with digital resistance attenuator.The audio signal amplitude stepping change value is 1dB in 0~100 dB amplitude range.Lumped multi-channel attenuation control is implemented using computer interface.
评论(0)
发评论
下载排行榜
