在BIST(内建自测试)过程中,线性反馈移位寄存器作为测试矢量生成器,为保障故障覆盖率,会产生很长的测试矢量,从而消耗了大量功耗。在分析BIST结构和功耗模型的基础上,针对test-per-scan和test-per-clock两大BIST类型,介绍了几种基于LFSR(线性反馈移位寄存器)优化的低功耗BIST测试方法,设计和改进可测性设计电路,研究合理的测试策略和测试矢量生成技术,实现测试低功耗要求。
- Abstract:
- During the BIST testing,LFSR as the TPG give very long test pattern for guaranteeing the fault coverage which due to a lot of power consumption.After analyzing the BIST structure and power loss model, the paper makes research on the al-gorithm and realization of lower power BIST on base of optimized LFSR aiming at two kinds of BIST architecture: the test-per-clock and test-per-scan. In order to meet testing lower power,the design methods for low power BIST circuit and reason-able test strategy are studied.
