基于TMS320F2812的震动信号处理系统设计
消耗积分:5 | 格式:rar | 大小:754 | 2010-12-27
王娟
分享资料个
 为解决战场目标识别系统识别精度不高的问题,提出一种基于震动信号实时分析的DSP系统,用于辅助战场目标识别。该系统采用TI公司的TMS320F2812型高速数字信号处理器(DSP)和3028震动传感器设计。实验结果证明该系统能够初步探测地面运动目标的震动信号,并对其实时分析和处理,并能够快速给出相应的分析结果。
Abstract:
 In order to resolve the problem which the accuracy of battlefield target identification system is not high,this paper puts forward the microseismic real-time processing and analysis system based on DSP for auxiliary battlefield target identification.The system design uses the high-speed digital signal processor TMS320F2812and3028vibration sensor.The experiment results show that the system detects the vibration signal of moving targets on ground,and quickly gives the corresponding of the analysis results.
评论(0)
发评论
下载排行榜
