Profibus-DP通信系统的设计
消耗积分:5 | 格式:rar | 大小:615 | 2010-12-31
分享资料个
针对采用WinCC等通用软件建立Profibus-DP网络不能满足大型系统中数据处理和监视的特定需求,提出一种基于VC的Profibus-DP通信系统的设计方案。采用VC++6.0编写通信程序,调用网卡CP5611驱动,Profibus-DP网络节点遵循Profibus-DP协议进行通信,实现PC机为一类主站,PLC S7-300和MM440变频器为智能从站的Profibus-DP通信系统。该系统设计已应用于大气综合计量检定装置。
Abstract:
 The Profibus-DP network builds through general software such as WinCC doesn’t meet the specific needs of data process and monitor in a large-scale system.A design scheme of Profibus-DP communication system based on VC is pro-posed.The system uses VC++6.0to generate a program,net card CP5611driver is called,Profibus-DP network nodes fllow the Profibus-DP protocol,and the nodes in the system comprises a PC as DM1,two PLC S7-300and two MM440as slaves.The design has been applied in atmospheric integrated measurement calobration device.
评论(2)
发评论
问天520 2012-11-16
0 回复 举报
......... 收起回复
wolongxq 2011-04-05
0 回复 举报
谢谢!够详细!我好好研究下 收起回复
下载排行榜
全部2条评论
