混合模式的嵌入式水环境在线监测系统
消耗积分:3 | 格式:rar | 大小:851 | 2011-01-04
申换换
分享资料个
针对当前我国水环境监测系统存在的问题,设计并实现混合B/S和C/S模式的嵌入式水环境在线监测Web服务器,并给出系统的总体设计方案,提出采用基于Web技术的B/S模式来完成对外公共服务的方案,并阐述如何使用有限状态机实现Web服务器。将基于C/S模式实现的监控服务器应用于复杂的传统监控,同时详细描述其各模块的实现方法及对应的数据包格式。测试结果表明:该系统功能完备,稳定性高,响应性能良好。
Abstract:
 In view of the problems existing in current water environment monitoring systems in China,an embedded server with water environment online monitoring based on the mixed mode of B/S and C/S was designed and implemented.We pro-posed a scheme which used B/S mode based on Web technology to realize exterior public services,and gave a description of how to use the finite state machine to achieve a Web server.Applying mornitor server realized based on C/S mode to com-plex traditional monitor.Moreover,detail designs of each module of the monitoring server were given with their packet format.The test results prove that the system has full functions,high stability and good response performance.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
