是德科技N1913A/N1914A平均值功率计
型号: N1913A/N1914A
品牌: (槟城电子)
--- 产品参数 ---
查看更多参数
公司logo
华易测电子
283內容 |  6.6w浏览量  |  12粉丝
--- 产品详情 ---
N1913A,N1914A(EPM系列)脉冲带宽功率传感器:
N1913A单通道功率计,宽动态范围:-70 至 +44 dBm(取决于传感器) ,频率范围:9 kHz 至 110 GHz(取决于传感器)
N1914A双通道功率计,宽动态范围:-70 至 +44 dBm(取决于传感器),频率范围:9 kHz 至 110 GHz(取决于传感器)
是德科技N1913A,N1914A,可兼容一下系列传感器:
N1913A,N1914A 单双通道功率计与所有 N8480、8480、U2000 系列和 E 系列传感器(E9320 系列除外)兼容,
并提供 -70 至 +44 dBm、9 kHz 至 110 GHz 的平均功率测量。
功率主机:E4416A,E4417A,E4418A,E4419A,E4418B,E4419B,N1911A,N1912A,N1913A,N1914A。
N1913A,N1914A功率计特点:
1,频率范围:9 kHz 至 110 GHz(取决于传感器)
2,宽动态范围:-70 至 +44 dBm(取决于传感器)
3,速度提升至 E 系列传感器的两倍:高达 400 个读数/秒
4,不仅可提供 GPIB 连通性,还可提供 LAN LXI-C 和 USB 连通性
5,可与 E4418B、E4419B 功率计兼容
6,可与 436A、437B 和 438A 功率计兼容(选件 200)
7,更多的测量通道数:多达三个通道,使用可选的 USB 主机端口可连接另外两个 U2000 系列功率传感器
8,利用可选的外部触发输入/触发输出特性自动进行频率/功率扫描测量
 N1914B EPM Series Dual-Channel Power Meter
The N1914B EPM series dual-channel average power meter provides repeatable and reliable results for bench/rack and field applications.
Highlights
  • Frequency range of DC to 120 GHz (sensor dependent)
  • Wide dynamic range of -70 to +44 dBm (sensor dependent)
  • Go beyond GPIB with LAN LXI-C and USB connectivity
  • Backward compatible with N1913/14A EPM Series single/dual-channel average power meters
  • Increased measurement channels: up to four channels with two additional U2000/U8480 Series and U2050/60 (except the peak power measurement) X-Series USB power sensors connected using the optional USB hosts
  • Automated frequency/power sweep measurements with the optional external trigger in/out feature
  • Your instrument now comes with the BenchVue Basic Power Meter/Sensor Control and Analysis App (BV0007B). The BenchVue software simplifies the process of connecting, controlling instruments, and automating test sequences. Download the BenchVue Basic App (BV0007B) for free to efficiently manage your power meter/sensor instruments
KeysightCare Logo
