--- 产品参数 ---
查看更多参数
公司logo
华易测电子
283內容 |  7.7w浏览量  |  12粉丝
--- 产品详情 ---
Agilent/keysight安捷伦3G数字信号源E4432B-E4436B
安捷伦ESG-D系列E4430B,E4431B,E4432B,E4433B信号发生器:
E4430B频率范围: 250KHz-1GHz
E4431B频率范围: 250KHz-2GHz
E4432B频率范围: 250KHz-3GHz
E4433B频率范围: 250KHz-4GHz
安捷伦ESG-DP系列E4434B,E4435B,E4436,E4437B信号发生器:
E4434B频率范围:  250KHz-1GHz
E4435B频率范围:  250KHz-2GHz
E4436B频率范围:  250KHz-3GHz
E4437B频率范围:  250KHz-4GHz
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B仪器选件说明:
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:1CM 机架安装配件
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:1CN面板把手配件
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:1CP带有把手的机架安装配件
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:1E5附加高wending度时基
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:1EM将所有面板连接器移到后面板上
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:UNA, UN8的另一个时隙功率电平控制选件
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:UNB,带有机械衰减器的高功率选件
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:UND,内部双ren意波形发生器
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:UN5,用于UND的单信道和多信道CDMA测量专用卡。
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:H03,单信道CDMA测量用卡
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:UN7,内部误码率分析仪
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:符合TDMA标zhun的实时I/Q基带发生器
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:UN9,用于UN8的附加7 Mbits RAM存储器
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:用于UND的W-CDMA测量zhuan用卡
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:H98,W-CDMA接shou机测试基带发生器
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:H99,W-CDMA、CDMA、TETRA的经改j的邻近信道功率(ACP)性能。
 主要技术指标:
1,250 kHz 至 1Ghz,2Ghz,3Ghz,4, GHz 频率范围,
2,RF 调制带宽达 35 MHz
3,可选的双ren意波形发生器,
4,和/或实时 I/Q 基带发生器
5,40 MHz 采样率和 14-bit I/Q 分辨率,
6,1 Msample (4 MB) 存储器用于波形回放
7, 1Msample (4 MB) 存储器用于波形保存
8,定制数字调制 (>15 种 FSK, MSK, PSK, QAM变异),AM, FM, 相位调制, 脉冲调制, 步进/表格扫描 (频率和功率),
9,GPIB 和 RS-232 连通能力
10,E443xB 性能升级
Agilent E4432B信号发生器, 3GHz
主要技术指标
250 kHz 至 3 GHz 频率范围
RF 调制带宽达 35 MHz
可选的双任意波形发生器
和/或实时 I/Q 基带发生器
1 Msample (4 MB) 存储器用于波形保存
GPIB 和 RS-232 连通能力
E4432B特点 :
供W-CDMA,cdma2000,EDGE和CDMA用的测量专用卡 * 用于I和Q的20MHz射频带宽
* 极高的电平精度
* 步进扫描(频率、功率和列表)
* 宽带调幅、调频和调相
* 内部数据发生器和突发脉冲功能(选件UN8)
* 灵活构成专门定制的调制(选件UN8,UND)
* 机内有供DECT、GSM、NADC、PDC、PHS和TETRA用的
* TDMA格式(选件UN8)内部双任意波形发生器(选件UND)
* 内部误码率分析仪(选件UND7)
OPTIONS:
E4432B - 1CM 机架安装配件,p/n 5063-9214
E4432B - 1CN 面板把手配件,p/n 5063-9227
E4432B - 1CP 带有把手的机架安装配件, p/n 5063-9221
E4432B - 1E5 附加高稳定度时基
E4432B - 1EM 将所有面板连接器移到后面板上
E4432B - UNA UN8的另一个时隙功率电平控制选件
E4432B - UNB 带有机械衰减器的高功率选件
E4432B - UND 内部双任意波形发生器
E4432B - UN5 用于UND的多信道和多信道CDMA测量专用卡
E4432B - H03 单信道CDMA测量专用卡
E4432B - UN7 内部误码率分析仪
E4432B - UN8 符合TDMA标准的实时I/Q基带发生器
E4432B - UN9 用于NU8的附加7MbitsRAM存储器
E4432B - 100 基于OPT UND的多信道W-CDMA测量专用卡
E4432B - 101 基于OPT UND的多信道cdma2000测量专用卡
E4432B - 201 基于OPT UND的多信道cdma2000测量专用卡
E4432B - 202 基于OPT UND的多信道EDGE测量专用卡
E4432B - H99 W-CDMA、CDMA、TETRA的经改进的邻近信 道功率(ACP)性能
