Yokogawa 横河AQ6317B高级光谱分析仪
型号: AQ6317B
--- 产品参数 ---
公司logo
诚兴仪器
1.6k內容 |  27w+浏览量  |  41粉丝
--- 产品详情 ---
AQ6317B是一款高级光谱分析仪,适用于各种应用,包括光源评估,光学设备中损耗波长特性的测量以及WDM(波分复用)系统的波形分析。
特别是在C波段和L波段,该装置可实现较高的波长精度和波长线性度,并可评估用于WDM的光学设备。分析功能使操作和扩展性变得简单。
规格:
波长范围:600至1750 nm
动态范围:60 dB(1523nm,峰值0.2nm,分辨率:0.01nm)
波长精度:0.5 nm(600至1750nm)
波长线性度:0.01nm(1520至1580nm)
波长重复性:0.005 nm(1分钟)
偏振相关性:0.05 dB(1550 / 1600nm),典型值0.05 dB (1310纳米)
附加信息
波长分辨率:分辨率设置:0.01、0.02、0.05、0.1、0.2、0.5、1.0、2.0nm
分辨率精度:5%
电平精度:0.3 dB
电平线性度:0.05 dB
扫描时间:约 500毫秒
The AQ6317B is an advanced optical spectrum analyzer for a wide range of applications, including light source evaluation, measurement of loss wavelength characteristics in optical devices, and waveform analysis of WDM (Wavelength Division Multiplexing) systems.
Especially at C-band and L-band, the unit achieves high wavelength accuracy and wavelength linearity, and can evaluate optical devices for WDM. Analysis functions make operation and expandability simple.
Specifications:
Wavelength Range: 600 to 1750 nm
Dynamic Range: 60 dB (1523nm, peak 0.2nm, resolution: 0.01nm)
Wavelength Accuracy: 0.5 nm (600 to 1750nm)
Wavelength Linearity: 0.01nm (1520 to 1580nm)
Wavelength Repeatability: 0.005 nm (1 min)
Polarization Dependency: 0.05 dB (1550/1600nm), 0.05 dB typ. (1310nm)
Additional Information
Wavelength Resolution: Resolution setting: 0.01, 0.02, 0.05, 0.1, 0.2, 0.5, 1.0, 2.0nm
Resolution Accuracy: 5 %
Level Accuracy: 0.3 dB
Level Linearity: 0.05 dB
Sweep Time: Approx. 500 ms
