禾洛ALL-200工程型万用烧录器 - 半导体芯片烧录-产品型录英文版
型号: 禾洛ALL-200 工程型/量产型 万用IC烧录器/编程器
--- 产品参数 ---
查看更多参数
公司logo
禾洛半导体
5內容 |  6.4k浏览量  |  0粉丝
--- 产品详情 ---
Product attributes of Heluo ALL-200 engineering
Product Features
Feature 1: Reliable programming performance
Independent research and development: Deep collaboration between software and hardware, ensuring stable and efficient programming of large-capacity ICs.
Intelligent protection: Full-pin automatic detection effectively prevents reverse insertion and poor contact.
Feature 2: Wide chip compatibility
Supported IC types: Supports a full range of chips including MCU/MPU, NOR/NAND Flash, EEPROM, SPI memory, FPGA, CPLD, and more.
Package coverage: Compatible with all mainstream package types including DIP, SDIP, SOP, SSOP, TSOP, PLCC, QFP, QFN, SON, BGA, and WLCSP.
Feature 3: Excellent quality of burner base
Durable: High-quality adapter board significantly extends the lifespan of the burner base.
Flexible expansion: Simply replace the corresponding base plate to accommodate new chips, offering strong scalability.
Feature 4: Convenient software operation
Clear interface: Real-time display of process status on the same screen, allowing intuitive control over the status of each seat.
Support Timeliness: The driver and support software are updated weekly to ensure rapid adaptation to new products.
product attributes
The ultra-high clock core circuit design significantly reduces the programming time of new-generation high-capacity memory ICs. The precise pin drive circuit provides high-speed, low-noise, accurate, and stable programming signals, meeting the programming requirements of special IC types, including high-speed and low-voltage types.
Core architecture: 16-bit overclocking core, equipped with FPGA/CPLD, for high-speed and precise control.
Processing performance: Ultra-high clock design significantly reduces the programming time for large-capacity chips.
Drive system: 56 sets of precision drive circuits, ensuring high-speed, low-noise, and stable signals.
Compatible range: Fully supports over 95% of MCUs on the market, making it the preferred choice for mass production.
Voltage support: Supports high-speed programming down to 1.8V, meeting the needs of special chips.
Hilo ALL-200 engineering/mass production universal IC burner/programmer - supports all types of chips such as MCU, Flash, FPGA, etc
