KEYSIGHT是德科技-样机2通道500M混合域示波器MSOX4052A与DSOX4052A-2通道5GSa/s采样率
InfiniiVision触摸屏4000A系列示波器:
MSO/DSOX4022A 示波器:200MHz带宽,5GSa/s采样率,2+16 通道,存储深度4M,
MSO/DSOX4032A 示波器:350MHz带宽,5GSa/s采样率,2+16 通道,存储深度4M,
MSO/DSOX4052A 示波器:500MHz带宽,5GSa/s采样率,2+16 通道,存储深度4M,
MSO/DSOX4102A 示波器:1GHz带宽,5GSa/s采样率,2+16 通道,存储深度4M,
MSO/DSOX4024A 示波器:200MHz带宽,5GSa/s采样率,4+16 通道,存储深度4M,
MSO/DSOX4034A 示波器:350MHz带宽,5GSa/s采样率,4+16 通道,存储深度4M,
MSO/DSOX4054A 示波器:500MHz带宽,5GSa/s采样率,4+16 通道,存储深度4M,
MSO/DSOX4104A 示波器:1GHz带宽,5GSa/s采样率,4+16 通道,存储深度4M,
MSO/DSOX4154A 示波器:1.5GHz带宽,5GSa/s采样率,4+16 通道,存储深度4M,
安捷伦/是德科技-示波器:
DSOX6002A,MSOX6002A,DSOX6004A,MSOX6004A,
DSOX4022A,MSOX4022A,DSOX4032A,MSOX4032A,
DSOX4052A,MSOX4052A,DSOX4102A,MSOX4102A,
DSOX4024A,MSOX4024A,DSOX4034A,MSOX4034A,
DSOX4054A,MSOX4054A,DSOX4104A,MSOX4104A,
DSOX4154A,MSOX4154A,
DSOX3012A,DSOX3022A,DSOX3032A,DSOX3052A,DSOX3102A,
DSOX3014A,DSOX3024A,DSOX3034A,DSOX3054A,DSOX3104A,
MSOX3012A,MSOX3022A,MSOX3032A,MSOX3052A,MSOX3102A,
MSOX3014A,MSOX3024A,MSOX3034A,MSOX3054A,MSOX3104A,
DSOX3012T,DSOX3022T,DSOX3032T,DSOX3052T,DSOX3102T,
DSOX3014T,DSOX3024T,DSOX3034T,DSOX3054T,DSOX3104T,
MSOX3012T,MSOX3022T,MSOX3032T,MSOX3052T,MSOX3102T,
MSOX3014T,MSOX3024T,MSOX3034T,MSOX3054T,MSOX3104T,
DSOX2002A,DSOX2012A,DSOX2022A,DSOX2004A,DSOX2014A,DSOX2024A,
MSOX2002A,MSOX2012A,MSOX2022A,MSOX2004A,MSOX2014A,MSOX2024A,
EDUX1002A,DSOX1102A,DSOX1204A,ESUX1002G,DSOX1102G,DSOX1204G
InfiniiVision触摸屏6000X系列示波器:
DSOX6002A 示波器:1 GHz ,2.5GHz,4GHz, 6 GHz带宽,20GSa/s采样率,2 通道,存储深度4M,
MSOX6002A 示波器:1 GHz ,2.5GHz,4GHz, 6 GHz带宽,20GSa/s采样率,2 + 16 通道,存储深度4M,
DSOX6004A 示波器:1 GHz ,2.5GHz,4GHz, 6 GHz带宽,20GSa/s采样率,4 通道,存储深度4M,
MSOX6004A 示波器:1 GHz ,2.5GHz,4GHz, 6 GHz带宽,20GSa/s采样率,4 + 16 通道,存储深度4M,
InfiniiVision触摸屏3000T系列示波器:
MSO/DSOX3012T 示波器:100MHz带宽,5GSa/s采样率,2+16 通道,存储深度4M,
MSO/DSOX3022T 示波器:200MHz带宽,5GSa/s采样率,2+16 通道,存储深度4M,
MSO/DSOX3032T 示波器:350MHz带宽,5GSa/s采样率,2+16 通道,存储深度4M,
MSO/DSOX3052T 示波器:500MHz带宽,5GSa/s采样率,2+16 通道,存储深度4M,
MSO/DSOX3102T 示波器:1GHz带宽,5GSa/s采样率,2+16 通道,存储深度4M,
MSO/DSOX3014T 示波器:100MHz带宽,5GSa/s采样率,4+16 通道,存储深度4M,
MSO/DSOX3024T 示波器:200MHz带宽,5GSa/s采样率,4+16 通道,存储深度4M,
MSO/DSOX3034T 示波器:350MHz带宽,5GSa/s采样率,4+16 通道,存储深度4M,
MSO/DSOX3054T 示波器:500MHz带宽,5GSa/s采样率,4+16 通道,存储深度4M,
MSO/DSOX3104T 示波器:1GHz带宽,5GSa/s采样率,4+16 通道,存储深度4M,
InfiniiVision不是触摸屏3000A系列示波器:
MSO/DSOX3012A 示波器:100MHz带宽,4GSa/s采样率,2+16 通道,存储深度4M,
MSO/DSOX3022A 示波器:200MHz带宽,4GSa/s采样率,2+16 通道,存储深度4M,
MSO/DSOX3032A 示波器:350MHz带宽,4GSa/s采样率,2+16 通道,存储深度4M,
MSO/DSOX3052A 示波器:500MHz带宽,4GSa/s采样率,2+16 通道,存储深度4M,
MSO/DSOX3102A 示波器:1GHz带宽,4GSa/s采样率,2+16 通道,存储深度4M,
MSO/DSOX3014A 示波器:100MHz带宽,4GSa/s采样率,4+16 通道,存储深度4M,
MSO/DSOX3024A 示波器:200MHz带宽,4GSa/s采样率,4+16 通道,存储深度4M,
MSO/DSOX3034A 示波器:350MHz带宽,4GSa/s采样率,4+16 通道,存储深度4M,
MSO/DSOX3054A 示波器:500MHz带宽,4GSa/s采样率,4+16 通道,存储深度4M,
MSO/DSOX3104A 示波器:1GHz带宽,4GSa/s采样率,4+16 通道,存储深度4M,
InfiniiVision 2000 X 系列示波器:
MSO/DSOX2002A示波器:70MHz带宽,2GSa/s采样率,2+16 通道,存储深度1M,
MSO/DSOX2012A示波器:100MHz带宽,2GSa/s采样率,2+16 通道,存储深度1M,
MSO/DSOX2022A示波器:200MHz带宽,2GSa/s采样率,2+16 通道,存储深度1M,
MSO/DSOX2004A示波器:70MHz带宽,2GSa/s采样率,4+16 通道,存储深度1M,
MSO/DSOX2014A示波器:100MHz带宽,2GSa/s采样率,4+16 通道,存储深度1M,
MSO/DSOX2024A示波器:200MHz带宽,2GSa/s采样率,4+16 通道,存储深度1M,
InfiniiVision 1000 X 系列示波器:
EDUX1002A示波器:50MHz带宽,1GSa/s采样率,2通道,存储深度100kpt,
DSOX1102A示波器:70/100MHz带宽,1GSa/s采样率,2通道,存储深度1M,
DSOX1204A示波器:70/100/200MHz带宽,2GSa/s采样率,4通道,存储深度1M,
EDUX1002G示波器:50MHz带宽,1GSa/s采样率,2通道,存储深度100kpt,
DSOX1102G示波器:70/100MHz带宽,1GSa/s采样率,2通道,存储深度1M,
DSOX1204G示波器:70/100/200MHz带宽,2GSa/s采样率,4通道,存储深度1M,
KEYSIGHT-是德科技12.1 英寸电容触摸屏示波器,InfiniiVision 4000 X 系列:
InfiniiVision 4000 X 系列数字存储示波器 主要特性与技术指标:
速度:
1,100 万个波形/秒的更新速率
2,wan美的 MegaZoom IV 智能存储器技术
3,标配的分段存储器
可用性:
1,业界zu1大的 12.1 英寸电容触摸屏
2,触摸式界面
3,创新的 InfiniiScan Zone 触摸触发
综合性:五位一体的综合性仪器,包括带宽在内的特x1ng均可进行升级
1,示波器
2,逻辑分析仪(MSO)
3,USB 端口串行协议分析仪(可选)
4,WaeGen 20 MHz 双通道函数/任意波形发生器(可选)
5,可提供 3 位电压和 5 位频率计数器测量的数字电压表(DVM)选件
InfiniiVision 4000 X 系列 数字存储示波器 描述
配有业界,zu1大的 12.1 英寸电容触摸屏,InfiniiVision 4000 X 系列便于使用的te性可能会让您大吃一j。它zhuan门针对触摸操作进行设计,使您可以减少示波器设置时间,将更多的时间用于进行设计和测试。
利用创x1n的 InfiniiScan Zone 触摸触发等能力,您只需在感兴趣的信号周围画一个框,4000 X 系列便可为您创建在该信号上的触发。只要能看见波形,便可在其上进行触发。
异chang和难以pu捉的事件是zu1难调试的事件。使用 MegaZoom IV 智能存储技术,4000 X 系列为您带来全新的使用体验,其业界l1ng先的 100 万个波形/秒的更x1n速率使您可以看到更多的信号特x1ng。4000 X 系列可提高设计的可kao性,使您对设计geng加充满信心。
