HV-2405/HV-2405E pdf datasheet
消耗积分:0 | 格式:rar | 大小:699 | 2009-01-03
王丽
分享资料个
The HV-2405E is a single chip off line power supply that
converts world wide AC line voltages to a regulated DC
voltage. The output voltage is adjustable from 5VDC to
24VDC with an output current of up to 50mA. The HV-2405E
can operate from input voltages between 15Vrms and
275Vrms as well as input frequencies between 47Hz to
200Hz (see Table 1 in section titled “Minimum Input Voltage
vs Output Current” for details).
评论(0)
发评论
下载排行榜
