汽车故障诊断与D类音频放大器
消耗积分:0 | 格式:pdf | 大小:175 KB | 2011-04-02
liuxin
分享资料个
  The MAX13300 automotive Class D audio amplifiers incorporate many built-in diagnostics to help locate faults in the system. The amplifiers detect the following fault conditions on the speaker outputs when there is no audio present. Since audio may not be present during these tests, those tests are typically run once at startup or only when requested in factory diagnostic mode.
评论(0)
发评论
下载排行榜
