液晶游戏机开源分享
消耗积分:0 | 格式:zip | 大小:0.13 MB | 2022-11-22
分享资料个
您好,它非常简单,因此无需解释,只需获取零件并使用接线图复制代码即可!
怎么玩!
PITF-ARD 点击开始。向右走找到门钥匙以完成关卡。向上移动操纵杆跳跃。
#include
#include
#include
LiquidCrystal_I2C lcd(0x27,16,2);
// VARIABLES DECLARATION
int game = 0;
int gameover = 0;
int le = 0;
float ll = 0;
int key = LOW;
int mov=0;
int cc=1;
int screen1[202];
int screen2[202];
int ind = 0;
int randomNumber=0;
int ax=0;
int ay=0;
int timegame=2000;
int clef = 0;
int jump = 0;
int path = 42;
int ck = 2;
// CHARS DECLARATION
byte man1[] = {0x04, 0x0E, 0x0E, 0x0E, 0x04, 0x04, 0x1F, 0x1F} ;
byte man2[] = {0x04, 0x1E, 0x05, 0x04, 0x0B, 0x10, 0x1F, 0x1F} ;
byte man3[] = {0x04, 0x0F, 0x14, 0x04, 0x1A, 0x01, 0x1F, 0x1F} ;
byte man4[] = {0x15, 0x0E, 0x04, 0x0E, 0x11, 0x00, 0x00, 0x00} ;
byte man5[] = {0x15, 0x0E, 0x04, 0x0E, 0x11, 0x00, 0x1F, 0x1F} ;
byte man6[] = {0x00, 0x00, 0x04, 0x0E, 0x04, 0x04, 0x1F, 0x1F} ;
byte flat[8] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x1F};
byte hole[] = {0x0E, 0x1F, 0x15, 0x1B, 0x0E, 0x04, 0x1F, 0x1F} ;
byte m1[] = {0x1F, 0x1F, 0x1F, 0x19, 0x10, 0x00, 0x00, 0x00} ;
byte m2[] = {0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x0F, 0x06, 0x00} ;
byte m3[] = {0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x0C, 0x00, 0x00} ;
byte m4[] = {0x1F, 0x1F, 0x00, 0x0A, 0x00, 0x0A, 0x00, 0x0A} ;
byte m5[] = {0x1F, 0x1F, 0x1F, 0x00, 0x0A, 0x00, 0x0A, 0x00} ;
byte m6[] = {0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x00, 0x0A, 0x00} ;
byte keys[8] = {0x00, 0x03, 0x1F, 0x13, 0x00, 0x00, 0x1F, 0x1F} ;
byte dooro[8] = {0x1F, 0x11, 0x11, 0x11, 0x11, 0x11, 0x1F, 0x1F} ;
byte door[8] = {0x1F, 0x1F, 0x1D, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F} ;
void setup(){
 lcd.init();
 lcd.backlight();
 lcd.home();
 lcd.clear();
// CHARACTER ASSOCIATION
 lcd.createChar(1, man1);
 lcd.createChar(2, flat);
 lcd.createChar(3, hole);
 lcd.createChar(8, keys);
 lcd.createChar(7, door);
void loop(){
 if (game == 0)
   if (gameover == 0)
     // TITLE SCREEN SCREEN
       lcd.home();
       lcd.setCursor(0, 0);
       lcd.print("  Key game");
       lcd.setCursor(0, 1);
       lcd.print(" 2020");
       key = digitalRead(7);
       if (key == LOW)
           // INIT GAME
           lcd.clear();
           lcd.home();
           le = 0;
           ll = 0;
           gameover = 1;
           cc=2;
           jump = 0;
           path = 16;
    else
          // NEW SCREEN - START
           randomSeed(analogRead(0));
           game = 1;
           key = LOW;
           le = le + 1;
           ll = ll + 1;
           path = path + 10;
           if (path>202)
           path = 202;
           ind = 0;
           for(int s=0;s<(path + 10);s++)
            screen1[s] = 2;
           for(int s=11;s<(path -2 );s=s+3)
            randomNumber = int(random(2, 4));
            //randomNumber = 3;
            screen1[s] = randomNumber;
           screen1[6]=7;
           screen1[path + 1]=8;
           for(int s=0;s<(path+10);s++)
            randomNumber = int(random(4, 7));
            screen2[s] = randomNumber;
          if ((ll/2) == int(ll/2))
             lcd.createChar(4, m4);
             lcd.createChar(5, m5);
             lcd.createChar(6, m6);
            else
             lcd.createChar(4, m1);
             lcd.createChar(5, m2);
             lcd.createChar(6, m3);
          timegame = 2000;
          clef = 0;
          cc = 2;
          ck = 2;
 else
 // GAME LOOP
     if (jump == 3)
     jump = 0;
     lcd.home();
     timegame = timegame - le;
     for(int s=ind;s<(ind+16);s++)
      lcd.setCursor(s-ind, 0);
      lcd.write(byte(screen2[s]));
      lcd.setCursor(s-ind, 1);
      lcd.write(byte(screen1[s]));
     if (timegame < 0)
       timegame = 0;
     lcd.setCursor(16-String(timegame).length(), 0);
     lcd.print(timegame);
if (jump == 0)
    lcd.setCursor(7, 1);
    lcd.write(byte(1));
    ck = screen1[ind+7];
    if (mov == 1)
     if (cc==1)
     else
     mov = 0;
     else
     mov = 1;
if (jump > 0)
      lcd.setCursor(7, 0);
      lcd.write(byte(1));
      lcd.createChar(1, man4);
      if (cc == 2)
      ind = ind + 1;
      else
      ind = ind - 1;
 if (jump == 1)
      jump = 2;
 else
      jump = 3;
     // CHECK LIVE OR DIE - LOOP GAME OR GAME OVER
     if ((ck == 2)&&(timegame>0))  // SET THE VARIABLE TO CHECK
     ay = analogRead(1);
     ax = analogRead(0);
     if ((ax > 600) && (jump == 0))
           if (ind<(path-7))
           ind = ind + 1;
           cc = 2;
           else
             screen1[path + 1]=2;
             clef = 1;
             lcd.createChar(7, dooro);
     if ((ax < 200) && (jump == 0))
           if (ind>0)
              ind = ind - 1;
              cc = 1;
           else
            if (clef==1)
             // CHECK LEVEL CLEAR - START
           lcd.print("                ");
           lcd.setCursor((int(10-String(le).length())/2),1);
           lcd.print("LEVEL ");
           lcd.print(le+1);
           delay(4000);
           lcd.clear();
           game = 0;
           gameover = 1;
//  CHECK LEVEL CLEAR - END
     if ((ay < 200) && (ind >1) && (ind <(path - 8)) && (jump == 0))
     jump = 1;
     delay(200);
// GAME LOOP - END
 else
//  GAME OVER - START
   if (timegame>0)
     lcd.print("   GAME  OVER :(   ");
     lcd.write(byte(1));
     lcd.createChar(1, man6);
     else
     lcd.print("   TIME  OVER   ");
     delay(4000);
     lcd.clear();
     game = 0;
     gameover =0;
//  GAME OVER - END
评论(0)
发评论
下载排行榜
