M68HC08,HCS08和HCS12应用笔记
消耗积分:0 | 格式:rar | 大小:188 KB | 2011-04-22
liuxin
分享资料个
This application note is an example of how to use the IIC
module on Freescale’s MCUs. The IIC module can be
used in the master or slave mode, respectively. In this
case, the master mode communicates with the serial
EEPROM because the IIC bus is used mainly for
communication between an MCU and a IIC peripheral
device. The IIC bus can communicate directly between
two MCUs, but the SPI bus is better for this task
评论(0)
发评论
下载排行榜
