带红外传感器的物体计数器
消耗积分:0 | 格式:zip | 大小:0.17 MB | 2023-02-06
马占云
分享资料个
带红外传感器的物体计数器
//made by Sujal Vasoya
//CD 4511 IC for 7 segment display
//pin 2,3,4,5 in first IC,pin 6,7,8,9 in second IC
//pin 10 in IR sensor out pin
#define ir 10
int count=0;
int j=1;
int i=1;
void setup() {
 pinMode(ir,INPUT);
 pinMode(2,OUTPUT);
 pinMode(3,OUTPUT);
 pinMode(4,OUTPUT);
 pinMode(5,OUTPUT);
 pinMode(6,OUTPUT);
 pinMode(7,OUTPUT);
 pinMode(8,OUTPUT);
 pinMode(9,OUTPUT);
 Serial.begin(9600);
void loop()
 int in_value=digitalRead(ir);
 if(in_value==LOW)
   Serial.print("count=");
   Serial.println(count);
   number2(j);
   Serial.print("j=");
   Serial.println(j);
    if(j==0)
      number1(i);
      Serial.print("i=");
      Serial.println(i);
      i++;
   j++;
   if(j==10)
     j=0;
   count++;
   if(count==100)
     count=0;
     i=1;
     j=1;
     number1(0);
     number2(0);
   delay(150);
void number1(int x)
{ if(x==0)
 digitalWrite(2,0);
 digitalWrite(3,0);
 digitalWrite(4,0);
 digitalWrite(5,0);
 if(x==1)
 digitalWrite(2,1);
 digitalWrite(3,0);
 digitalWrite(4,0);
 digitalWrite(5,0);
 if(x==2)
 digitalWrite(2,0);
 digitalWrite(3,1);
 digitalWrite(4,0);
 digitalWrite(5,0);
 if(x==3)
 digitalWrite(2,1);
 digitalWrite(3,1);
 digitalWrite(4,0);
 digitalWrite(5,0);
 if(x==4)
 digitalWrite(2,0);
 digitalWrite(3,0);
 digitalWrite(4,1);
 digitalWrite(5,0);
 if(x==5)
 digitalWrite(2,1);
 digitalWrite(3,0);
 digitalWrite(4,1);
 digitalWrite(5,0);
 if(x==6)
 digitalWrite(2,0);
 digitalWrite(3,1);
 digitalWrite(4,1);
 digitalWrite(5,0);
 if(x==7)
 digitalWrite(2,1);
 digitalWrite(3,1);
 digitalWrite(4,1);
 digitalWrite(5,0);
 if(x==8)
 digitalWrite(2,0);
 digitalWrite(3,0);
 digitalWrite(4,0);
 digitalWrite(5,1);
 if(x==9)
 digitalWrite(2,1);
 digitalWrite(3,0);
 digitalWrite(4,0);
 digitalWrite(5,1);
void number2(int y)
{ if(y==0)
 digitalWrite(6,LOW);
 digitalWrite(7,LOW);
 digitalWrite(8,LOW);
 digitalWrite(9,LOW);
 if(y==1)
 digitalWrite(6,HIGH);
 if(y==2)
 digitalWrite(7,HIGH);
 if(y==3)
 if(y==4)
 digitalWrite(8,HIGH);
 if(y==5)
 if(y==6)
 if(y==7)
 if(y==8)
 digitalWrite(9,HIGH);
 if(y==9)
img20211120141229_ZE35gnZr9r.jpg?auto=compress%2Cformat&w=740&h=555&fit=max
1 / 4
评论(0)
发评论
下载排行榜
