nRF905 pdf datasheet
消耗积分:0 | 格式:rar | 大小:333 | 2008-04-11
分享资料个
nRF905 is a single-chip radio transceiver for the 433/868/915 MHz ISM band. The
transceiver consists of a fully integrated frequency synthesiser, receiver chain with
demodulator, a power amplifier, a crystal oscillator and a modulator. The
ShockBurst
TM feature automatically handles preamble and CRC. Configuration is
easily programmable by use of the SPI interface. Current consumption is very low, in
transmit only 11mA at an output power of -10dBm, and in receive mode 12.5mA.
Built in power down modes makes power saving easily realizable.
•  True single chip GFSK transceiver in a small
32-pin package (32L QFN 5x5mm)
•  ShockBurst™ mode for low power operation
•  Power supply range 1.9 to 3.6 V
•  Multi channel operation – ETSI/FCC
Compatible
•  Channel switching time <650µs
•  Extremely low cost Bill of Material (BOM)
•  No external SAW filter
•  Adjustable output power up to 10dBm
•  Carrier detect for "listen before transmit"
nrf905应用电路图
protocols
•  Data Ready signal when a valid data package
is received or transmitted
•  Address Match for detection of incoming
package
•  Automatic retransmission of data packages
•  Automatic CRC and preamble generation
•  Low supply current (TX), typical 11mA
      @ -10dBm output power
•  Low supply current (RX), typical 12.5mA
•  Wireless data communica
•  Alarm and security system
•  Home Automation
•  Remote control
•  Surveillance
•  Automotive
•  Telemetry
•  Industrial sensors
•  Keyless entry
•  Toys
评论(1)
发评论
liangshaozhi 2015-11-24
0 回复 举报
无线模块 收起回复
下载排行榜
全部1条评论
