OTDR技术在缠绕式光纤传感阵列结构状态监测中的应用
消耗积分:0 | 格式:rar | 大小:124 | 2009-06-23
张亮
分享资料个
给出了一种新颖的、利用多模光纤缠绕钢绳式传感阵列网络,对智能材料与结构的
受力、应变等状态参量进行监测和估计,并采用OTDR 技术实时处理并行分布式传感信号。实验结果表明,此系统能够对结构的状态进行在线监测和估计,具有一定的实用价值。
关键词:  光纤传感器; 智能材料与结构; OTDR
Abstract :  A novel sensor array made of twined steel2cable2like multimode optical fibers is
presented. It can be used to detect many state parameters such as load and st rain of intelligent material and st ructure. OTDR technology is applied to process real2time parallel and dist ributed sensing signals. The experiment result s demonst rate that this system can be used to detect and estimate st ructure and state online , which is of practical value.
Key words :  fiber optic sensor ; intelligent material and st ructure ; OTDR
评论(0)
发评论
下载排行榜
