详述LM3447 TI可控硅调光IC(全英版)
消耗积分:1 | 格式:pdf | 大小:521KB | 2014-07-23
风雷电
分享资料个
The LM3447 is a versatile power factor correction (PFC) controller designed to meet the performance requirements of residential and commercial phase-cut dimmer compatible LED lamp drivers。The device incorporates a phase decoder circuit and an adjustable hold current circuit to provide smooth,flicker free dimming operation。 A proprietary primary side control technique based on input voltage feedforward is used to regulate the input power drawn by the LED driver and to achieve line regulation over a wide range of input voltage。
评论(0)
发评论
下载排行榜
