清晰的ADS805电路电路图
消耗积分:0 | 格式:pdf | 大小:55KB | 2014-08-13
titititi
分享资料个
The ADS805 is a 20MHz, high dynamic range, 12-bit, pipelined Analog-to-Digital Converter ADC。 This converter includes a high-bandwidth track-and-hold that gives excellent spurious performance up to and beyond the Nyquist rate. This high-bandwidth, linear track-and-hold minimizes harmonics and has low jitter, leading to excellent Signal-to-Noise Ratio (SNR) performance。 The ADS805 is also pin-compatible with the 10MHz ADS804 and the 5MHz ADS803。
评论(1)
发评论
灭魂小怀 2015-07-30
0 回复 举报
看看 收起回复
下载排行榜
全部1条评论
