ADG3231,pdf datasheet (Transla
消耗积分:0 | 格式:rar | 大小:552 | 2009-09-25
分享资料个
The ADG32311 is a single-channel level translator designed on a submicron process that is guaranteed to operate over the 1.65 V to 3.6 V supply range. The device can be used in applications requiring communication between digital devices operating from multiple supply voltages. The logic levels on each side of the device are set by the two supply voltages, VCC1 for A and VCC2 for Y. The signal path is unidirectional, meaning data can flow only from A to Y.
评论(0)
发评论
下载排行榜
