• Embedded Microcontroller – 16-Bit RISC Architecture up to 16‑MHz Clock – Wide Supply Voltage Range (1.8 V to 3.6 V) (1) • Optimized Ultra-Low-Power Modes – Active Mode: Approximately 100 µA/MHz – Standby (LPM3 With VLO): 0.4 µA (Typical) – Real-Time Clock (LPM3.5): 0.25 µA (Typical) (2) – Shutdown (LPM4.5): 0.02 µA (Typical) • Ultra-Low-Power Ferroelectric RAM (FRAM) – Up to 64KB of Nonvolatile Memory – Ultra-Low-Power Writes – Fast Write at 125 ns Per Word (64KB in 4 ms) – Unified Memory = Program + Data + Storage in One Single Space – 1015 Write Cycle Endurance – Radiation Resistant and Nonmagnetic • Intelligent Digital Peripherals – 32-Bit Hardware Multiplier (MPY) – 3-Channel Internal DMA – Real-Time Clock (RTC) With Calendar and Alarm Functions – Five 16-Bit Timers With up to Seven Capture/Compare Registers Each – 16-Bit Cyclic Redundancy Checker (CRC) • High-Performance Analog – 16-Channel Analog Comparator – 12-Bit Analog-to-Digital Converter (ADC) With Internal Reference and Sample-and-Hold and up to 16 External Input Channels • Multifunction Input/Output Ports – All Pins Support Capacitive Touch Capability With No Need for External Components
