最小的24位模数转换器的使用
消耗积分:0 | 格式:rar | 大小:0.08 MB | 2017-05-05
分享资料个
  模数转换器即A/D转换器,或简称ADC,通常是指一个将模拟信号转变为数字信号的电子元件。通常的模数转换器是将一个输入电压信号转换为一个输出的数字信号。由于数字信号本身不具有实际意义,仅仅表示一个相对大小。故任何一个模数转换器都需要一个参考模拟量作为转换的标准,比较常见的参考标准为最大的可转换信号大小。而输出的数字量则表示输入信号相对于参考信号的大小。
  线性技术的LTC2400是世界上第24位ADC的SO-8封装。创新三角洲西格玛体系结构得到了发展。结果是小,高精度,简单易用的∑-∑模数转换器。这纸是为了教育用户的几个主题与Δ∑转换器相关联并消混乱与这个新的一杆,或没有延迟∆ΣTM,建筑。这里讨论的关键主包括速度、噪声、PGAs、线频率,抑制,输入电流,多路复用,模拟输入范围和键特征区分从其他DeltaSigma LTC2400ADCs。
  VII. Key Features Differentiating the LTC2400 from the Competition
  1. S0-8 Package—The LTC2400 is the smallest 24-bit ADC on the market.
  2. Absolute Accuracy —The total unadjusted error (TUE) of the LTC2400 is less than 10ppm over 2.7V to 5.5V supply and –45°C to 85°C operation.
  3. On-Chip Oscillator—The LTC2400 does not require external crystals or oscillators.
  4. Live at Zero—The LTC2400 continues to resolve signals below ground up to –12.5% of VREF
  5. Overrange—The LTC2400 continues to resolve signals above VREF up to 12.5% of VREF.
  6. High Accuracy INL—The integral nonlinearity of the LTC2400 is 4ppm with a 5V reference and 2ppm with a 2.5V reference
  7. High Accuracy DNL—The LTC2400 outputs 24 bits with no missing codes (guaranteed monotonic)。
  8. Low Noise—0.3ppm RMS (1.5µVRMS) noise.
  9. Ultralow Offset—The offset of the LTC2400 is within 1ppm.
  10. Very Low Offset Drift—The offset of the LTC2400 drifts less than 1ppm over the entire temperature range –45°C to 85°C. This corresponds to 0.01ppm/°C drift. No external calibration is required.
评论(0)
发评论
下载排行榜
