解决方案:专注于意法半导体传感器
继续我们的系列检测传感器领域的主要参与者,在这篇文章中我们将仔细看看传感器产品和技术的全球半导体公司意法半导体提供。自称为世界上最大的MEMS制造商,该公司成功地开发半导体解决方案横跨微电子应用的频谱。ST供应智能传感器和轮毂等产品;加速度计;汽车传感器;陀螺仪;湿度传感器;MEMS器件;压力、温度、电子罗盘传感器和接近;和iNEMO惯性模块和触摸屏控制器,使得ST的组合非常广泛和深入。
研究院IHS公司在最近的一份报告中指出,传感器中心- ST的重点将发挥关键作用,在未来的传感。这些集线器从充满力量的应用处理器卸载任务,使一个单一的电池充电的移动设备更长的功率,并启用“总是”性能。出货量增长估计为三位数的水平在2014与6亿5840万个单位,同比增长百分之154,从2亿5960万个单位在2013,根据IHS。从2014到2017,IHS预计将增加百分之1300,出货量高达13亿台。
STMicroelectronics uses an external hub approach, as does Atmel, Texas Instruments and NXP, for smartphones including Apple’s iPhone 5s, Samsung’s Galaxy S5, and the Motorola Moto X. Another of its sensor hub approaches is an MCU combined with single or multiple sensors such as accelerometers and gyroscopes. InvenSense and STMicroelectronics are the main providers of solutions using this approach, while Bosch, Freescale Semiconductor, and Kionix offer products in this segment as well.
ST’s sensor portfolio ranges from discrete to fully-integrated solutions. It uses high-performance sensor fusion to improve the accuracy of multiaxis sensor systems and it has MEMS foundries, assembly, and test capabilities, allowing it to be a complete in-house dual source for its customers.
