超低功耗系统的电池升压
消耗积分:0 | 格式:rar | 大小:0.13 MB | 2017-06-22
分享资料个
  超低功耗系统的电池升压
  最近在储能、电池升压和电源管理设备方面的技术进步推动了能源收集部门,特别是无线传感器网络应用领域的快速增长。本文将着重介绍一些设备、评估板和开发工具包的示例,它们可以帮助设计者开发这种快速移动技术。
  在没有布线或电池更换的情况下为传感器网络供电的能力开辟了一系列新的应用,如智能楼宇控制、工业控制、安全、资产追踪和环境监测。从环境中清除能量,包括阳光、振动或温差以驱动这些无线传感器网络的系统正在变得越来越流行,有人会说无处不在。这主要是由于电力管理设备的技术进步,使收割能源得到更有效的利用。
  有些传感器网络系统可以访问足够的环境能量源,使它们能够自主运行,并且几乎无限期地运行。例如,工业机器、火车或桥梁上的传感器可以从振动中获取能量,这样就可以设计出足够的环境能量,使传感器能够读取数据并传输数据。其他一些情况下,能量只能间歇地获得(如光伏电池),或者在能量不足的情况下,需要某种形式的能量储存装置。蓄电池或超级电容器是首选的储能设备。
  How frequently sensor readings need to be taken and transmitted depends very much on the specific application, and this affects energy storage design decisions. Generally, these systems are designed to be predominantly in standby mode, requiring only a few microwatts of power. The sensor circuitry only wakes up periodically to take and send a reading. Some applications may only require sensors to be read a couple of times an hour. Others may be programmed to wake up only once or twice a day or once a week. However, real time monitoring is growing in interest in the transportation sector and for industrial machine monitoring, for example. It is in this area that improvements in energy storage technology, as well as power management, are facilitating growth.
评论(0)
发评论
下载排行榜
