使用被动式红外传感器作运动探测器时的设计考虑
消耗积分:0 | 格式:rar | 大小:0.31 MB | 2017-07-11
分享资料个
  运动探测器已经持续监视我们十多年了。这些无处不在的热释电眼睛可以检测到从小偷闯入你的房子到顾客进入超市的一切。
  早期设计不可靠。以传感器为基础的自动照明,例如,往往会超时,让你在黑暗中尝试杂技演习重新触发,并使光回来。但是更好的材料、传感器、处理器、算法、镜头和系统设计使运动探测器更加实用,成本更低,而且比过去更可靠。
  本文讨论的技术和设计背后的被动红外(PIR)探测器,它考虑的是在几乎每一个低成本的运动检测系统的心脏。它将审查可用的检测器的类型,检查它们的问题和好处,并为成功地将运动检测功能添加到您的设计中提供必要的设计提示。。
  The pyroelectric effect
  The pyroelectric effect was first documented in Greece in 314 BC, when it was observed that when heated, tourmaline attracted bits of straw and ash. This was re-discovered in the 18th century and the phenomenon was attributed to electricity, but without an understanding as to how. Continued research in the 19th century by Pierre Curie and Jacques Curie uncovered the mechanisms behind the pyroelectric effect and a new technology was born.
评论(0)
发评论
下载排行榜
