IEC-60065-2001中英文对照
消耗积分:2 | 格式:pdf | 大小:1196KB | 2017-07-17
limitezhong
分享资料个
IEC-60065-2001中英文对照
  1) The IEC (International Electrotechnical Commission) is a worldwide organization for standardization comprising all national electrotechnical committees (IEC National Committees)。 The object of the IEC is to promote international co-operation on all questions concerning standardization in the electrical and electronic fields. To this end and in addition to other activities, the IEC publishes International Standards. Their preparation is entrusted to technical committees; any IEC National Committee interested in the subject dealt with may participate in this preparatory work. International, governmental and non-governmental organizations liaising with the IEC also participate in this preparation. The IEC collaborates closely with the International Organization for Standardization (ISO) in accordance with conditions determined by agreement between the two organizations. 国际电工委员会是由各国家电工委员会(IEC国家委员会)组成的世界性标准化组织,其目的是促进电工电子领域标准化问题的国际合作。为此目的,除其它活动外,IEC发布国际标准。国际标准的制定/撰写由技术委员会承担,对所涉及内容关切的任何IEC(成员的)国家委员会均可参加标准的制定工作,与IEC有联系的任何国际、政府和非官方组织也可以参加国际标准的制定。IEC与国际标准化组织ISO根据两组织间协商确定的条件保持密切的合作关系。 2) The formal decisions or agreements of the IEC on technical matters express, as nearly as possible, an international consensus of opinion on the relevant subjects since each technical committee has representation from all interested National Committees. IEC在技术问题上的正式决议或协议,是由对这些问题特别关切的国家委员会参加的技术委员会制定的,对所涉及的问题尽可能地代表了国际上的一致意见。 3) The documents produced have the form of recommendations for international use and are published in the form of standards, technical reports or guides and they are accepted by the National Committees in that sense. 这些决议或协议以标准、技术报告或导则的形式发布,以推荐的形式供国际上使用,并在此意义上,为各国家委员会所认可。 4) In order to promote international unification, IEC National Committees undertake to apply IEC International Standards transparently to the maximum extent possible in their national and regional standards. Any divergence between the IEC Standard and the corresponding national or regional standard shall be clearly indicated in the latter. 为了促进国际上的统一,各IEC国家委员会有责任使其国家和地区标准尽可能采用IEC标准,IEC标准与相应国家和地区标准之间的任何差异应在国家或地区标准中指明。 5) The IEC provides no marking procedure to indicate its approval and cannot be rendered responsible for any equipment declared to be in conformity with one of its standards. IEC不以标志的形式表示认可,对任何声明符合其标准的设备也不承担责任
评论(1)
发评论
dengminn 2017-08-31
0 回复 举报
谢谢分享 收起回复
下载排行榜
全部1条评论
